Does anyone know what this means?
It keeps popping up in my Houdini Dialog Box.
WARNING: OPUI_DialogPRM2: Symbol “open.val” value stepped on.
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294f760, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294da80, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294dfc0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c294ece0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c1bbca00, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205918bd480, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c286ef20, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205918bcd00, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c8912140, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x2058f6a3340, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205c89120e0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x2058f6a3880, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a183e080, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a183eb60, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a183dd80, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x20599bbb940, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a959f640, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a959d480, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a943ffa0, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x205a9771360, name=“RE_WindowWindow”) , parent: QWindow(0x0) , transient parent: QWindow(0x0)
*** OCTANE API MSG: Tried to access null node
*** OCTANE API MSG: Tried to access null node pin
Error code?
8737 5 0-
- reelinspirations
- 178 posts
- Enivob
- 2658 posts
- iam83
- 16 posts
- blackpixel
- 182 posts
Stumbled upon the same thing today and it's not related to any external renderer in my case.
Seems like Houdini has a problem with (spare) parameters with the name “open”.
Creating a spare parm with that name produces the same warning and the parameter pane for that node stops updating correctly ( when creating keys, deleting channels etc ).
Edited by blackpixel - Oct. 6, 2017 09:11:34
- HandcraftedMedia
- 22 posts
I've been running into this issue a lot! It seems to happen when I have an Octane a material that is using a custom parameter from inside the nodes. In my case, I had a RGB color node I wanted to control form the “shop level” of that material. I feel like Octane for Houdini is causing a lot more crashes than a professional render engine should cause!
Anyone have found a fix for this!
- eschwab
- 63 posts
