I started using Python in Houdini just recently, perhaps this is something basic I am missing.
I want to update menu parm with some Python logic when SOP is created. Then each time menu is being changed(clicked and selected new value), I do another logic.
The problem is, whenever I do setParmTemplateGroup() on HDA object, some variables are being changed. I dont get whats going on. Please see attached hda and code. If you bypass setParmTemplateGroup() line, it works fine, x=20. If I update menu parm with new values/labels, x=10, even tho it was set to 20 onCreated.
import hou x = 10 labelList = ["one", "two", "three"] itemList = ["one", "two", "three"] def updateUI(node, myitemList, mylabelList): parm = node.parm("menuParm") hda = node.type().definition() ptg = hda.parmTemplateGroup() menuParm = node.parm("menuParm") template = menuParm.parmTemplate() template.setMenuItems(myitemList) template.setMenuLabels(mylabelList) ptg.replace("menuParm", template) hda.setParmTemplateGroup(ptg) def changedMenu(): global x print ("changed menu: " + str(x)) def onCreated(node): global x, itemList, labelList print ("on created: " + str(x)) x = 20 print ("on created value updated: " + str(x)) updateUI(node, itemList, labelList) print ("after updated UI: " + str(x))
