Heya, this should be pretty simple but I can't wrap my head around. I assembled a little test scene for show purpose.
The upper mesh (or lower) shall have the exact time and the copies of it should get x frames offset per step.
I used the copy stamp paramater only for random values in some tutorials. I am not sure how I can get a controlled output. The For-each loop has the same problem. It bakes my time after every step. (I guess instancing is also an option but I assume there's some knowledge needed which is too heavy for me right now.)
Heya, thanks for your answer. I thought trails were only for computing the trails itself so that idea definitely helped but in this case I also want to offset the translation of each iteration.
