Is there way to get XY slider Parameter UI in Houdini? (2 Axis Slider)
   2114   2   1
Hello.
I'm a new be to use Houdini. and I have some question.
The thing is I can't figure out make animation controller just like 3dsmax or maya.
custom controller box that rectangle contains a handle and move the handle to manipulate x and y together.
I found that in Houdini usually do it with 2 of single float slider parameters but,
it would be dramatically help with x,y together like other programs can. (controlling eye balls or jaw movement etc..)
So, if there is a way to add parameters like attached image?
and if it's not possible in default what solution I could try on?
Hope I made my point. Thank you.
XY slider parameter UI Needed.jpg (115.6 KB)
That's a great feature request!
If you need something RIGHT NOW, you can fake it with a ramp, see attached.
ramp_as_xy_controller.hipnc (64.5 KB)
mestela
my god I didn't know that a ramp cloud be used like this!
thank you very much! you made my day : )
