how can I use unix commands using the tcsh that is shipped with houdini?
I was about to download cygwin….but I found a post somewhere saying there is a shell that is shipped with houdini….
how is this accessed in the textport?
thanks in advance for anyhelp!
using unix with tcsh from textport
7025 13 0- lynch_ppl
- 176 posts
- edward
- 7714 posts
- lynch_ppl
- 176 posts
- edward
- 7714 posts
Sorry, by “Command Line Tools”, I meant the menu item by that name from the Start menu (ie. Start > All Programs > Side Effects Software > etc…).
From the Houdini textport, you can use the “unix” command (see online help). It basically spawns a csh instance to execute the command.
As for the PATH environment variable. Right-click on My Computer, choose Properties > Advanced > Environment Variables.
- lynch_ppl
- 176 posts
- edward
- 7714 posts
- lynch_ppl
- 176 posts
I just starting using unix on mac os and found it very useful…
I think there is a lot of cool tricks you could come up with like automating the setting up of creating folders to render to…or creating textfiles from information that is being passed back and forth…
so I just finished up the install… went into the properties and the environment variables..
in the user variables I created new…
then set variable to PATH
then set value to C:\cygwin
is this correct?
the cygwin folder is in the root of C:
is this correct?
- edward
- 7714 posts
- lynch_ppl
- 176 posts
- lynch_ppl
- 176 posts
- deecue
- 412 posts
in order for ls to work, you'll need an ls alias pointing to the opls command (or you could just use opls)..
that alias should be already set up in new houdini launches (see 123.cmd).. but to check, go to settings->aliases and variables (Alt-A)..
edit: i just noticed you said nothing prints at all, which is odd.. if it doesn't recognize a command, you should atleast be getting a ‘unknown command’ return.. don't know what to say there..
Dave Quirus
- lynch_ppl
- 176 posts
my variables do have the ls and opls alias set….
i am not trying to print out operators though…not sure if I'm being 100% clear
I am trying to print a list of directories of folders on my hardrive in the unix working directory… which you can find ou the location by typing “upwd”
so I am then navigating using “ucd”…so I am not navigating in houdini…but on the computer…
I am using “unix ls” to print out a list of directories in the current working unix directory….
hopefully this clears things up…
still no output…
still no output…
- edward
- 7714 posts
- lynch_ppl
- 176 posts
