BUG (Cops): Magical Alpha Generation for non 8-bit planes
   2249   1   0
Houdini 8.0.454
There appears to be some sort of “off by one” error happening when you have a non 8 bit image that is composited on (Over/Atop/etc) a image sequence.
Check out /img/img1/over1 at frame 8.
Its a Color COP composited over a Image Sequence that ended the previous frame.
If the color cop is set to 8-bit integer then you get a 0 alpha (good), but if you set it to 32bit you get an alpha (bad).
COP_Bug.hip.gz (5.0 KB)
Fixed for tomorrow's build (8.0.475).
