I was doing some tests with “Render With Takes” and I'm getting mixed results I would expect. Here are some of the tests I tried. (Bold settings are the ones that differ from the Base Case.)
No parameters have been added to the A take. The hip take is where all the parameters are being set.
What is expected? What is a bug?
Mantra ROP with…
Base:
Current Take - A
Output Picture - $ACTIVETAKE.main.tif
Render With Take - (Current)
Output - A.main.tif
Result - Expected
Case 1:
Current Take - hip
Render With Take - A
Output - hip.main.tif
Result - Bug?
Case 2:
Current Take - hip
Output Picture - `run(“takeset”)`.main.tif
Output - A.main.tif
Result - Expected
Case 3:
(Note: Mantra ROP is wired into a Batch ROP. The Render Button on the Batch ROP is the one being pushed. The Render With Take is being set on the Batch ROP.)
Current Take - hip
Render With Take (Mantra ROP) - (Current)
Render With Take (Batch ROP) - A
Result - Bug?
I'm basically looking for a way to set up my ROPs so that I can just set the paths to query what the current take is in my hip take, that way I don't have to micromanage all the different outputs for the different takes.
I can kinda understand why $ACTIVETAKE isn't 100%. But the `run(“takeset”)` kinda scares me in the Case 3. I would have thought the Batch ROP would have overrode whatever the Mantra ROP had set.
Render With Take.
2973 4 0- wolfwood
- 4256 posts
- edward
- 7714 posts
- malexander
- 5156 posts
Case #2 is a bug. You should be getting A.main.tiff. I suspect the output picture parm is being evaluated before the take is being applied, or perhaps the parm value is being incorrectly cached.
Case #3 is correct. The “render with take” option only applies to that ROP. In fact, the Batch ROP probably shouldn't have that parm at all, since it doesn't do any rendering. Though I suppose you could set its single parm differently in takes :wink:
The only node whose “Render with Take” parm affects other nodes is the Subnet ROP - it sets its take for the duration of the rendering of the children, so any child with Render with Take set to ‘Current’ will use the parent subnet's take.
- wolfwood
- 4256 posts
twod
You mean Case #1?
2d
Ahh.. Good to know. So many new ways of working….so little time to test.
Thanks Mark.
- malexander
- 5156 posts
