This is a weird one. Doing viewport flipbooks in 8.0.468 stops every 30 frames or so until I wiggle the mouse. Very strange… SuSE 10.0, FX 5200 , Nvidia drivers 7676
Peter B
BUG: Flipbook freezing strangely
3503 5 1- pbowmar
- 7024 posts
- JColdrick
- 4140 posts
Running the same OS/drivers and haven't noticed that at all. Must say my first instinct is that it's something to do with window focus and the window manager, since it's a GL grab it might be finicky about focus. Assuming you're running KDE, I'm running with Control Center/Desktop/Window Behaviour/:
Focus Policy = “Focus Follows Mouse”
No auto-raise
No delay focus
No click-raise active window
Might want to try that if you aren't already and see if it helps.
J.C.
P.S. Currently running 8.0.473, although as mentioned never noticed it before.
No auto-raise
No delay focus
J.C.
John Coldrick
- pbowmar
- 7024 posts
- JColdrick
- 4140 posts
- malexander
- 5156 posts
- pbowmar
- 7024 posts
The generation in Houdini. The CPU would still be pegged, but nothing would advance. I would then wiggle the mouse and it would proceed as normal. It's a pretty fast flip, maybe 3 fps or so, so it's pretty obvious when it does it.
The change to the mouse focus fixed it so I've moved on )
Peter B
Peter B
