Autorig Errors
2615 9 2- ctedin
- 69 posts
Does anyone else get these errors? I make a “auto rig”, and move all the guide “bones” around in the proper location. I save out the “Extra JSON” file as well, that contains the rig definitions. I even export the JSON file too. I save the .hip file, so I can come back and adjust the rig once I bake out a test rig. All goes well, but if I open the old file, then do a File>Load From Existing Asset, I get some errors. When I bake out a new rig, it errors out around the ankles and gives me an error. I delete the whole “auto rig”, and generate a new one from the saved JSON file. I get this result:
- goldfarb
- 3455 posts
- ctedin
- 69 posts
- goldfarb
- 3455 posts
- ctedin
- 69 posts
I'm not sure exactly. I believe that I tried it on 16.0.6xx some version in that series. However, I did totally recreate it in this very latest version (.736) with the same results. I rebuilt the preference folder prior to starting again, so there shouldn't have been any connection with the prior version.
Thanks for looking into this. I've been in class today all day long, so I haven't been able to check the forum.
- ctedin
- 69 posts
- clayawodey
- 6 posts
- goldfarb
- 3455 posts
- ctedin
- 69 posts
- hashman63
- 11 posts
arctorUnfortunately, this problem is in 16.5 on different builds, 268, 345.
There have been a couple of changes to the way that modules parent to each other.
In the next major release (H16.5 - next week!) these two AutorigSettings files should import without issue and build.
I've tested both today.
thanks for your patience
Edited by hashman63 - Jan. 11, 2018 08:50:01
