Hello!
How i can add arrow like this for my interface parameter?
How add selector to Parameter Interface?
3833 2 4- Danil Shaposhnikov
- 58 posts
- neil_math_comp
- 1743 posts
In the Type Properties dialog, select the parameter you'd like to add the button to, and under the Action Button tab, you can add something like:
On the Parameter tab, you might or might not also need to add 3 entries in the Tags table (where the last entry's text is multiple lines). It might or might not be automatically filled in if you just fill in the Action Button tab, (I'm not an expert on that front).
import soputils
kwargs['geometrytype'] = hou.geometryType.Primitives
kwargs['inputindex'] = 0
soputils.selectGroupParm(kwargs)
script_action_icon BUTTONS_reselect
script_action_help Select geometry from an available viewport.
script_action import soputils
- 58 posts
ndickson
In the Type Properties dialog, select the parameter you'd like to add the button to, and under the Action Button tab, you can add something like:import soputils
On the Parameter tab, you might or might not also need to add 3 entries in the Tags table (where the last entry's text is multiple lines). It might or might not be automatically filled in if you just fill in the Action Button tab, (I'm not an expert on that front).script_action_icon BUTTONS_reselect
Thank you very much.
