Attachment Not Found
bind export affects principle shader
2992 4 2- Nicolas Heluani
- 280 posts
- Nicolas Heluani
- 280 posts
Ok, I solve part of the issue….
Apparently the issue happens when bind exporting the data outside of the material.
if I bind export it inside the principle shader everything is peachy…
I already reported it as a bug, as we should be able to bind export data outside as to properly use the power of the new material context….
- JasonSlab
- 1533 posts
- Richard Costin
- 101 posts
- Nicolas Heluani
- 280 posts
JasonSlab
Yes this is a bit of a issue with the new MAT context, connecting binds to the shader as a property of sorts is a good idea.
Yep… The new MAT context is an awesome system.
So requiring to incorporate AOVs into each shader will kind of defeat that purpose.
I think this problem happens only when dealing with packed primitives and point color so I already report it as a bug:
bug #86507
