I'm trying to write a particular shader “from the ground up” as a learning exercise. I'm an old-school graphics programmer but just learning VEX and VOPs. Using Houdini 16.5.
My question is this: the BSDF is an opaque type. There's a few VOPs/VEX functions to create one, “diffuse” and a few others. I'm looking for the “noop” BSDF, that just always returns the incident ray – i.e. fully transparent, no refraction or opacity or anything. I'd like it to be really fast.
The reason I'm asking is I want to write a shader which is emissive-only. I know how to export Ce, but I'm stuck on creating the “noop” F. Right now I'm using pbrglass with ior set to 1 which works, but when I look at the VEX code I can see it's doing a lot more work than I need (i.e. it's calling get_bsdf(“phong”)).
Any advice appreciated!
Fully transparent BSDF?
1996 6 0- garyo
- 32 posts
- jsmack
- 7762 posts
the no op bsdf is
check out shaderlayer.h for an example of a noop bsdf
Edit:
To elaborate, a bsdf in mantra does not determine opacity or emissivity. To do that you need to make a complete surface shader. The Of export sets opacity, an the Ce export sets emission.
bsdf()
Edit:
Edited by jsmack - Nov. 22, 2017 19:47:55
- garyo
- 32 posts
jsmack
the no op bsdf is
bsdf()
True – I found that. But that bsdf reflects all incoming energy randomly in a hemisphere around the normal, as far as I can tell; i.e. it's perfectly diffuse with zero transmission. I'm looking for a (fast) bsdf that takes all incoming energy and continues it (“refracts” it) through the object in the same direction, i.e. the ideal transparent object. I understand I can set Of to 0 but that's not what the glass shader does, for instance. (Again, as far as I can tell – I could very well be wrong.) I would expect (hope?) such a bsdf to be even faster than the bsdf() one you mention above, since it doesn't need to randomize anything.
- tamte
- 8548 posts
garyowhy would you want to do what glass shader does? Setting Of to 0 is much more efficient than using refractive bsdf
… I understand I can set Of to 0 but that's not what the glass shader does…
so empty bsdf() with Of to 0 and whatever emission you want should be very efficient as no light or geometry sampling will be invoked from such shader
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- garyo
- 32 posts
tamte
Ah, I see! Thanks very much for the help. If Of>0, then the bsdf will get sampled, but not if it's exactly zero. That's helpful.
- jpparkeramnh
- 178 posts
- tamte
- 8548 posts
garyo
empty bsdf() should already not cause any sampling
Of to 0 is just to get it fully transparent without using any raytracing if all you want to do is just send the ray through
Edited by tamte - Nov. 28, 2017 05:28:05
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
