Hello, this is my first post.
I installed Houdini 16.5.322 QT4 and i'm unable to run the apprentice application at all.
I get a fatal error on startup every time.
My system specs:
MAC Pro mid 2010
CPU:
intel Xeon 2x6 core 2.66 GHZ
RAM:
24GB 1333 MHZ DDR3
Graphic card:
ATI Radeon HD 5770 1024 MB
Attached is the crash log.
I will appreciate any suggestion, please.
Thank you,
Dario
Houdini 16.5 crashes on startup on OSX
2794 5 2- DiagrammaStudio
- 1 posts
- christopherw
- 48 posts
The ATI Radeon HD 5770 is a really old graphics card (and 1GB VRAM is not enough to run Houdini). We recommend a graphics card with at least 2GB VRAM. See https://www.sidefx.com/Support/system-requirements/ [www.sidefx.com] for full requirements.
- Rebus B
- 80 posts
Having same problem. Mac OS10.10.5 NVIDIA Quadro 4000 2048 MB
Previous version ran fine. 16.5.323 ran for a while, now crashes on start. Uninstalled all Houdini versions, rebooted, reinstalled. Now always crashes (Fatal Error) on start after windows come up. Saves empty scene file on crash.
Console reports:
1/3/18 10:12:32.000 PM happrentice: dyld: lazy symbol binding failed: Symbol not found: _clock_gettime
Referenced from: /Applications/Houdini/Houdini16.5.323/Frameworks/Houdini.framework/Versions/16.5.323/Libraries/./libcurl.dylib
Expected in: /usr/lib/libSystem.B.dylib
1/3/18 10:12:32.000 PM happrentice: dyld: Symbol not found: _clock_gettime
1/3/18 10:12:32.333 PM happrentice: CFUserNotificationDisplayAlert: called from main application thread, will block waiting for a response.
Checked for library named above and it does exist on system.
If latest version will not work, can we downgrade a version to one that does with Apprentice (please?)
Console reports:
Edited by Rebus B - Jan. 3, 2018 22:20:03
- rvinluan
- 1255 posts
Rebus B
Console reports:
This error is related to Houdini anonymous stats.
The workaround is to disable anonymous stats like so:
- open a terminal and navigate to ~/Library/Preferences/houdini/16.5- Open hcommon.pref in a text editor. If the file does not exist, then create it first.
- In the text editor, look for `sendAnonymousStats` and set it to 0. Or if `sendAnonymousStats` cannot be found, then add a new line:
sendAnonymousStats := 0
- Restart Houdini
Rob
- rvinluan
- 1255 posts
Rebus B
Console reports:
The ‘_clock_gettime’ startup crash is fixed as of tomorrow's Houdini 16.5.351 build. You will need to wait until tomorrow to get access to this build from the daily builds download page.
Rob
- Rebus B
- 80 posts
- Restart Houdini
This fixed it! Thanks Rob.
