I was waiting some time, before someone else notices this, but we got several production builds and this still exist. Its not only my PC, but other PCs in company as well. So i would want to double check with others as we cant use H16.5 due to this error.
So whats going on.
Alembic node, set to default Delayed load, assigning color node - nothing happens in viewport. Sometimes it updates and then there is no way how to get rid of this color. All is updating fine on spreadsheet, just not in viewport. Also shading is pretty messed up, loading wrong geo (visible in wireframe, where pieces are missing edges), black areas, no edges.
If i load the geo as unpacked all goes away. But this is not acceptable for our heavy assets as it makes Houdini super slow (not problem of this build, just houdini in general).
Houdini 16.5+ and alembic errors, unable to work with
4074 16 2- martinkindl83
- 260 posts
- jsmack
- 7737 posts
https://www.sidefx.com/forum/topic/15603/ [www.sidefx.com]
submit a bug, and maybe SideFX can figure out how to fix it.
- martinkindl83
- 260 posts
- jsmack
- 7737 posts
- martinkindl83
- 260 posts
- jsmack
- 7737 posts
- martinkindl83
- 260 posts
- mawi
- 242 posts
- anon_user_89151269
- 1755 posts
- martinkindl83
- 260 posts
- vusta
- 555 posts
well to prove jsmack's point, I test with 16.0
01) torus
02) assemble, enable pack
03) color red
does not show color, disable pack will show color
substitute the assemble with copytransform, make 5 copies, pack and instance
same result, will not show color, disable pack will
pretty easy test to repro…no need for any complicated geo…alembic or not….
01) torus
03) color red
- martinkindl83
- 260 posts
- vusta
- 555 posts
- martinkindl83
- 260 posts
I'm not attacking anyone. Sorry if that sounded offending. I started thread about alembic and people are throwing at me houdini packed geo. I can confirm that packed alembic is showing color in viewport for h13, h14, h15, h15.5,h16.0
Not working in H16.5.
Not mentioning that biggest issue is disapearing geo. Color is problem as well just not as big (but certainly would stop us from using houdini)
- jsmack
- 7737 posts
- martinkindl83
- 260 posts
- martinkindl83
- 260 posts
