Sorry if I miss it somehow somewhere, and it's again about UI, that maybe boring, but I can't find if it's possible or not, and if it is - how to do the following:
Would like to pin not just a particular node's Parameters to a context, but parameters of all nodes of this context (want it for a floating another context).
E.g. I have ‘/obj’ near the viewport and I pin it.
I have say “/out” floating with his own parameters and pin it too.
Both contexts have several nodes. If I pin a node's parameters inside one of them, I can select any other node there and parameters will be for the pinned one. And this is what we need this option seems for.
And I can select in this situation different nodes in another context floating and parameters will be changed there respectively to the changed selection (if the parameters network is not pinned).But how to keep both opened networks pinned, and let parameters be changed if I select different nodes within them, but don't give parameters be intersected between contexts.
And don't know how to call it - let's say - Parameters pinned to a selected node - First level pinning, what I try to achieve - Second level pinning.
Sorry if explanation is not enough clear.
Feel free to correct me if needed.
Appreciate help and advices.
Thanks.
