Hello im new to houdini im switching from c4d to houdini and i need to make some realistic fur. I whant to use render man whit my indie licence but i dont understand why is no working ?
i put a renderman node in the render section put a light for renderman and when i press render in the render view its make loading scène and nothing happen or houdini just crash
if you have a recent tutorial how how to use renderman ? i take it ;-)
How tu use renderman ?
2249 5 2- bgood
- 141 posts
- Konstantin Magnus
- 670 posts
- bgood
- 141 posts
- bgood
- 141 posts
- jujoje
- 185 posts
The /.env file you need to edit is located here on macOS:
~/Library/Preferences/houdini/16.5/houdini.env
I think the rest of the setup should be the same as the video. Just add these lines:
# Renderman
RMANTREE=/Applications/Pixar/RenderManProServer-21.0
PATH=$RMANTREE/bin:$PATH
Replacing 21.0 with whatever version you’re using.
# Renderman
- bgood
- 141 posts
Thank you ;-)
but still not working i have modified the file select renderman in houdini hos is showed in the vidéo but nothing
between “rendererman” that I can't activate and Arnold who doesn't calculate an image if I give him an hdri it's hard to get started. for arnold I have to create a variable environment to give it the license server port but I don't know how to write it “ solidangle_LICENSE=5053@localhost (change port and server if necessary)
In short, very frustrating
Edited by bgood - Jan. 9, 2018 11:49:58
Sorry for my english but i learn too ^^
1 ryzen 3970X 64go
1 xeon hexacore 32go
1 i7 hexacore 16o
1 ryzen 3970X 64go
1 i7 hexacore 16o
