I have a simple setup where I am using a copy to points node and assigning a random texture to the copies.
The only way I have found to get the texture to update in the viewport is to apply the random texture in the material override.
I would really like to be able to manipulate the texture selection in VOPS using by defining the basecolor_texture string. However this only seems to be visible when rendering. The viewport defaults to the texture which is defined in the material. I need to see how textures are working without doing a software render every step.
Is there a setting or process I can use to enable or force the viewport to show the correct textures - the ones that render?
thanks in advance
Jeff
random texture randomness not visible in viewport
1512 4 0- jeffMc
- 125 posts
- malexander
- 5158 posts
The process available is the one you've already described - apply the random texture as a material override.
The viewport does not evaluate VOP networks, as this would be tremendously expensive in terms of updates and redraws. If you need to see the result of a VOP network as a material, the Render View is what is generally used. Edit: or the render region in the 3D viewport.
Edited by malexander - Jan. 11, 2018 09:49:02
- jeffMc
- 125 posts
- jeffMc
- 125 posts
- jsmack
- 7759 posts
