We analyzed the cause of the bug (https://www.sidefx.com/forum/topic/51866/), and found out the following.
When we extract *.json file from the Houdini 16.0.504 build, the coordinates of the guides are saved in the format with high precision, for example:
“fingersroot”: {
“translate”: [
“5.73010652716e-05”,
“-0.0146017434347”,
“0.0610589732365”
“rotate”: [
“0.0”,
“0.0”,
“0.0”
Houdini 16.5 saves these data in the abridged version with only 6 decimal places, for example:
“fingersroot”: {
“translate”: [
“5.730106”,
“-0.014601”,
“0.061058”
“rotate”: [
“0.0”,
“0.0”,
“0.0”
Because of this, the data are distorted, and after reloading, the coordinates of the guides are put wrongly.
Maybe, this infotmation will help you fix the bug earlier.
Autorig saving Errors in Houdini 16.5
1283 4 1- hashman63
- 11 posts
- goldfarb
- 3455 posts
- hashman63
- 11 posts
- goldfarb
- 3455 posts
- hashman63
- 11 posts
