Moving pivot to the bottom in python?
   2777   5   0
How do you guys move the pivot to the bottom of the object?
I tried to make new shelf button by modifying the python script for (Move pivot to center) shelf icon:
import toolutils
scene_viewer = None
activepane = toolutils.activePane(kwargs)
parent = activepane.pwd()
if activepane.type() != hou.paneTabType.SceneViewer:
# Use the last selected object
if parent.childTypeCategory() != hou.objNodeTypeCategory():
raise hou.Error("This tool cannot be executed in this context")
selected = [child for child in parent.children() if child.isSelected()]
else:
scene_viewer = toolutils.sceneViewer()
selected = scene_viewer.selectObjects(
prompt = toolutils.selectionPrompt(hou.objNodeTypeCategory()),
allow_multisel = True,
allowed_types = ("geo",))
if len(selected) == 0:
raise hou.Error("Nothing was selected")
for center_obj in selected:
display = center_obj.displayNode()
if display is None:
pivot = hou.Vector3(0, 0, 0) # Use 0,0,0 by convention
else:
geo = display.geometry()
pivot = geo.boundingBox().center()
center_obj.parmTuple("p").set(pivot)
if scene_viewer is not None:
scene_viewer.setCurrentState("pose")
Tried “pivot = geo.boundingBox().center()” to “pivot = geo.boundingBox().bottom()”
but it's not working with me.
Is there other solution?
Edited by jomaro - Jan. 19, 2018 08:01:39
Hello, jomaro,
if you need to
you can try this
pivot = geo.boundingBox().minvec()
it will move the pivot to the bottom corner of the boundingBox.
*if your question wasn't about the center of the bottom
Edited by RyuKu - Jan. 19, 2018 22:39:05
Thank you so much Ryu Ku,
My question actually was about moving the pivot to the center of the bottom but thank you that will keep me trying to understand the python more and more
Have a lovely day
here, in the else part put this in:
    else:
        pivot[0]=0
        pivot[2]=0
(ie. get minvec then set x,z components to 0)
I'm not a coder so will not accept responsibility if you blow up your 'puter..
Edited by vusta - Jan. 21, 2018 00:48:59
vusta
    else:
        pivot[0]=0
        pivot[2]=0
Wow, thank you so much, that's it
vusta
    else:
        pivot[0]=0
        pivot[2]=0
This method isn't working anymore don't know why.
Anyone have a fix?
