Hi there!
I used the old version of the Houdini Cvex in the new mat CvexShader, which was unable to run. But it works under the ShOP module,
Another problem is that in ShOP, the Cvex pointreater cannot render the sequence, and the single frame can be rendered.
about houdini 16.5 PointReplicate Cvex Question
1775 2 1- kuimig
- 16 posts
- jsmack
- 7737 posts
- kuimig
- 16 posts
jsmack
I've used CVEX procedurals in the mat context successfully, although not the point replicate procedural. Are you using the collect VOP to apply the geometry shader(point replicate procedural) to the object?
Thank you for your reply, I used Point Replicate Procedural and Cvex shader in Mat.
And in the geo module Procedural Shader parameters panel called them.
