I'm using the hou module in a custom python script. The process I am using is that I set the needed environment variables inside the python script via os.environ and add Houdini's python2.7libs folder to the sys.path before finally importing the hou module as per the documentation.
However when I load a hip file via hou.hipFile.load I get errors saying that houdini can't find some of the custom HDA's it contains. I keep these HDA's in a special folder for asset management purposes and made sure that it was included in the ‘HOUDINI_PATH’ environment variable that I set before importing hou. However, running hou.houdiniPath reveals that houdini sees the variable as set to what appears to be default values. If I then os.getenv the variable by name it does show it as being set and containing the proper folder that contains the hda/ and otl/ folders where I keep the missing assets. Confusing…
Is this a bug? Am I doing something wrong?
Hou module not picking up HOUDINI_PATH
2206 3 3- NFX
- 183 posts
- rvinluan
- 1255 posts
- zephmann
- 5 posts
I haven't tried recreating this, but like Rob was saying, maybe try hou.setenv to set the HOUDINI_PATH instead of sys.path.
I'm not exactly sure of the order, but could it also be that Houdini is sourcing the HDAs before the path is updated, in which case you could try running hou.hda.reloadAllFiles() after updating the path?
Good luck!
Good luck!
FX TD - The Mill, Los Angeles, CA
- NFX
- 183 posts
Using hou.putenv() to set the ‘HOUDINI_PATH’ before loading the file seems to do the trick. Thanks for the suggestion Zephmann!
The odd thing is that hou.houdiniPath() still returns the wrong values, even though everything else works. Either way files are loading now without complaining and that is what I needed.
Also yes this was running from python with me handling initialization of the env vars and importing the hou module.
Edited by NFX - Feb. 9, 2018 20:05:13
