Random primitive selection changing over time progressively (City Lights Windows timelapse)?
1775 6 2- Adriano
- 408 posts
I'm trying to create a random selection of primitives, of all the windows of the buildings of a city-scape, and have it change progressively over time. I'll use the attribute of that selection to generate lights (Geo with self-Lit Material) to simulate people turning on and off the lights in their apartments / offices.
I've been trying to achieve that with a Sort node (Primitive sort Random) and a blast node with some expressions, but my vex skills are quite poor and i'm hitting a brick wall on this one.
Any idea how to go about it please?
A.
A.
Edited by Adriano - Feb. 7, 2018 22:33:51
- martinkindl83
- 260 posts
- Adriano
- 408 posts
- matthias_k
- 483 posts
See: http://www.sidefx.com/docs/houdini/model/attributes.html [www.sidefx.com]
Shading
shop_materialpath string
The path to a material to use to shade the surface when rendering. Overrides the object’s material is present on primitives.
On detail, prim
attached is a simple example
simply animate the sort or use a channel in the wrangle… whatever you like.
sorry, forgotten to say, you can use this to assign different groups, too
and then assign materials by group.
Shading
On detail, prim
Edited by matthias_k - Feb. 8, 2018 15:38:58
- Adriano
- 408 posts
- matthias_k
- 483 posts
- Adriano
- 408 posts
Thanks Matthias, interesting stuff, cheers for that.
But it still doesn't really solve my issue here. Although the attribute transfer method made me think of a bit of an overkill solution that could however work in my case without having to science the S out of this. I'm just going to use POPs and generated random particles with a short random lifespan and use the generated particle (sphere or boxes, whatever works) and transfer attributes from those onto my city scape. Going to be heavy, but i don't have an other solution right now.
Thanks again.
A.
Thanks again.
A.
