Render job on single machine ? Hqueue ?
4408 14 2- bgood
- 141 posts
Hello i have a lot of render to start , its possible to make a render job whit one single machine ? i have tried to make a server , the server works on my machine, but I can't get the client to work if I enter the name of my machine which is Mac Pro I have this message " nodename nor servname provided, or not known“. or failed to add ”Mac Pro"
Sorry for my english but i learn too ^^
1 ryzen 3970X 64go
1 xeon hexacore 32go
1 i7 hexacore 16o
1 ryzen 3970X 64go
1 i7 hexacore 16o
- bgood
- 141 posts
- rvinluan
- 1255 posts
bgood
Just to clarify, it sounds like you are unable to add a second machine, “Mac Pro”, as a client to your farm. If that's the case, then it sounds like a general networking problem. Most likely DNS is not setup for your machines so your server machine does not know how to connect to the “Mac Pro” machine.
My suggestion would be to use IP addresses instead of machine names. So enter the IP address in the machines list instead of “Mac Pro”.
Rob
- rvinluan
- 1255 posts
- bgood
- 141 posts
Sorry I'm French my English is not very good: -)
So I can run the server and client from the same machine?
I saw that osx had created a user account hqueue client.
Is it possible to launch under the same session client and server or do I have to switch each time?
so the ip address to enter is 127.0.0.0.1?
1 ryzen 3970X 64go
1 i7 hexacore 16o
1 ryzen 3970X 64go
1 i7 hexacore 16o
- rvinluan
- 1255 posts
- bgood
- 141 posts
- bgood
- 141 posts
- bgood
- 141 posts
- bgood
- 141 posts
- rvinluan
- 1255 posts
- rvinluan
- 1255 posts
bgood
I have tested and i have an error message “failed to add 127.0.0.1 ”
It might be a permission issue.
Even though you are attempting to add the same machine as a client you might need to enable remote login access in Mac.
System Preferences -> Sharing -> Remote Login
Edited by rvinluan - Feb. 14, 2018 10:08:15
- bgood
- 141 posts
- rvinluan
- 1255 posts
- bgood
- 141 posts
