Hi everybody
this is my first post, I'm happy (and scared at the same time )to be here with you.
How can I get the edge_dir attribute ,the one was in Point “add force” in Hou.15.5 and earlier versions,in Hou 16?
Is there a Vex function that makes the same without using the Point sop?
thanks for your help
E.
add force in old Point sop
3435 4 1- paniruro
- 17 posts
- neil_math_comp
- 1743 posts
If I recall correctly, it's something like just a tangent vector, in which case, you can hopefully use one of the options in PolyFrame. I might be completely misremembering though, since I never used it, myself.
- paniruro
- 17 posts
Hi @ndickson , thanks for the quickest reply ever
I just tried PolyFrame sop and it doesn't give a good result. My bad maybe, but the tangent vectors i'm looking for (the ones old Point vop gave) are pointing to a different direction. PolyFrame gives a result close to that a cross product does.
Regards
E.
Regards
E.
Edited by paniruro - March 4, 2018 12:45:13
- bonsak
- 459 posts
- paniruro
- 17 posts
