Hey all. Does anyone know if there is a way to make a parameter change while inside a sub-take, but have it affect all takes like it would making a parameter change at the global level?
I find myself using takes for lookDev purposes under different lighting schemes and when I want to nudge something globally I need to go back to the main take, make the change, then go back to the take I was using as a lookdev take and check it out. Bake to main take, make a change, back to sub-take.
Wanted to make sure there wasn't a hidden gem I'm missing with the take system. Thank you.
Takes - global parameter change inside of take
1068 2 1- 9krausec
- 66 posts
- tamte
- 8444 posts
not big fan of takes, but
can you just have your Mantra/IPR set to the take you are lookdeving in?
then you can stay in Main, keep doing global changes and IPR will still render your lookdev take, so no need to jump back/forth unless you need to do specific changes in the lookdev take itself
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- 9krausec
- 66 posts
