Hi!
I'm trying to make a 2x4 wood rail but it tilts in different sections. I tried to set the normals of the curve to point up but it doesn't affect the sweep.
Any Ideas?
Thanks.
-Olivier
SWEEP: up direction?
2491 2 0- olivierth
- 1004 posts
- tamte
- 8449 posts
if Transform Usng Attributes is checked then you'd have to define full rotation using N/v+up or as orient
when Off however, the third input's points are used as reference for up vector
so just branch from your curve, move each point in upvector direction and connect into 3rd input
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- olivierth
- 1004 posts
