I'm trying to work around a Redshift limitation where RS Incandescent shaders can not affect volumetric scattering.
The scene is a bunch of buildings being instanced across a grid using Point-Old Instancing with this bit of random distribution “/obj/Building_`floor(fit01(rand($PT),1,10))`/”.
I then created identical copies of each instance, with same suffix digit, same order, but kept only the polygons matching the windows with lights on those buildings. I checked, if i use a Point instancing, they line up perfectly on top of my other instances.
Now since Redshift Materials can not affect volumetric scattering, i need to use those windows polygons as source in a Redshift Mesh Light. In order for Redshift to pick up those polygons they need to be present in the scene as geometry, consequently i must “Copy Stamp” them across my scene in the same exact fashion as the point instancing does with my buildings. I brought them all into a switch using object merge nodes, threw the same script into the stamp, but referring to my Windows polygons geometries “/obj/Building_Lights_`floor(fit01(rand($PT),1,10))`/” And sadly that did not do the trick. I checked the order of the geos in the switch node, reversed that order, and nope, still won't line up.
So is there something i'm missing here please. Doesn't “”/obj/GEO`floor(fit01(rand($PT),1,10))`/" always return the same result in any context? I'm not sure what could interfere with that result.
A.
identical distribution between a "Copy Stamp Node" and "Point-Old Instancing"?
1234 2 1- Adriano
- 408 posts
- Enivob
- 2529 posts
It might be that your geo object that is hosting the windows has been scaled or translated. I noticed that the mesh light expects the mesh it is referencing to have a unity matrix. i.e. world origin. Once I reset my mesh light geo matrix everything lined up.
Edited by Enivob - March 11, 2018 10:45:15
Using Houdini Indie 20.0
Ubuntu 64GB Ryzen 16 core.
nVidia 3050RTX 8BG RAM.
- Adriano
- 408 posts
