should I continue a sim if it runs out of ram?
2298 2 0- ouroboros1221
- 79 posts
- Enivob
- 2529 posts
Turn off your OpenCL and try again. Your simulation may be too large to fit within the vRam you have. By using CPU only you may yet still achieve success. But monitor your physical ram usage as well. If you exceed physical ram you are out of luck and will have to lower the quality of your simulation or install more physical memory.
Using Houdini Indie 20.0
Ubuntu 64GB Ryzen 16 core.
nVidia 3050RTX 8BG RAM.
- kelvincai
- 74 posts
