Attachment Not Found
RIGGING (More deformation trouble, cant seem to understand whats going on with capturing/skinning inside Houdini)
1308 4 1- traileverse
- 355 posts
Hi everyone, Here (In the Attached file) I have 6 separate bones riveted to a NURBS surface, when I capture a tube geometry using these bones, I have no clue what the deformations are doing, even when painting capture weights it's not doing whats expected. Where am I messing up? Thanks in advanced.
hou.f*ckatdskmaya().forever()
- goldfarb
- 3455 posts
your capture regions became offset from your bones (you can see they don't match by displaying the bonecapturelines SOP)- to fix this:
put your NURBS surface back to normal
select all your bones
Rigging Shelf > Align Capture Pose
you should see a notification about the number of bones aligned
now you can move your NURBS ribbon
- traileverse
- 355 posts
- goldfarb
- 3455 posts
- traileverse
- 355 posts
