I have some points that are created randomly on a grid, now I need to instance an animation for every point, and I need the animation to start only when a point is created.
I would use copy stamp with timeshift but how can I tell timeshift to start the animation only when a point is created ?
For example in the simple scene I uploaded, the spheres have a little animation when they appear, I want every sphere to start the animation when its template point is activated, but they are all in sync.
Anyone can help ?
Thank you
Timeshift and copy stamp
2451 3 1- madrenderman
- 129 posts
- vusta
- 555 posts
- madrenderman
- 129 posts
- Aizatulin
- 472 posts
here is an idea, where I've used a point attribute from the grid, which gives you control, when the animation will start. For example you can use the distance from zero. I've created a wrangle for the sphere, where an offset parameter can be passed to a ramp or a channel to gain control of the size (of the sphere) over time for each point of the grid.
