Move Pivot to Center, issue ...
2083
4
0
Masoud
March 18, 2018 8:34 a.m.
Hello;
Has anyone used the “Move Pivot to Center” from modify shelf?
I want to move pivot of a mesh back to it's center, but it doesn't work.
Here is a simple test scene, that I attached:
Pivot_Reset_Test.hip (57.8 KB)
Masoud Saadatmand (MSDVFX)
March 18, 2018 9:10 a.m.
Hello Masoud, the Move Pivot to Center works when I open your file, you could also just zero out the “pivot translates” param on the object. For the move pivot to center tool, I select object then hit the shelf tool and it works.
hou.f*ckatdskmaya().forever()
Masoud
March 18, 2018 11:11 a.m.
Hi Patrick; When I press “Move Pivot to Center” button, Houdini shows this error:
Edited by Masoud - March 18, 2018 11:15:47
jsmack
March 18, 2018 9:51 p.m.
Build 268 is the release build. You should move on to one of the recent production builds, as numerous bugs were fixed.
Masoud
March 29, 2018 12:24 a.m.
Thank you jsmack, you are right.
Edited by Masoud - March 29, 2018 00:25:33
