Anyone know where I can get a list of ALL the shortcuts that exist for houdini 8? I know there used to be one kicking around (http://www.sidefx.com/community/index.html) [sidefx.com] however, it no longer exists.
thx,
Sealth
list of shortcuts
6969 5 2- Sealth
- 50 posts
- edward
- 7714 posts
- Sealth
- 50 posts
Hey Edward, thx for the reply. Well to be perfectly honest with you I am not too sure by what you mean when you say “bound” hotkeys. I have tried browsing the hotkey editor, however for some reason (maybe it is one of my settings) you need to actually click on the operation you want to perform to see what the hotkey is for it. I want to see a list of all the hotkeys available for each viewer pane. I know that you can get a list by pressing “ctrl + RMB” but you just get a floating pane. I wanted a text file that I could print out and start to memorize by using. I guess that I could just do a print screen while doing the “ctrl + RMB” but I thought that there may have been a help screen that gave a list of all the default hotkeys for different viewports etc. I've also tried looking in C:\Program Files\Side Effects Software\Houdini 8.0.383\houdini\config\Hotkeys however, the naming convention is a little too convoluted to understand - I can't even find an entry that is the viewport.
thanks.
Sealth
thanks.
Sealth
~the most important things in life aren't things~
- symek
- 1390 posts
- rmagee
- 1182 posts
- WillA
- 98 posts
