Hi guys,
i'm pretty new to Houdini and sometime i lack certain knowledge of how to use certain things correctly.
What i'm trying to do is the following:
https://www.dropbox.com/s/h2owvbb1pl34uiy/spiral.PNG?dl=0 [www.dropbox.com]
I have a spline with a number of points on it, and i want to rotate every single point of this spline to rotate around one axis with an increasing angle, to get some kind of a spiral along the surface which is made out of the same spline with an revolveSOP.
In my opinion it shouldn't be that hard, but i seem to use the wring expressions or so.
Any Tips you could provide?
Thanks in advance and greetings
Spiral along surface
1419 2 0- Moonraiker
- 1 posts
- BabaJ
- 2036 posts
You might want to have a look at this tutorial:
http://www.entagma.com/td-fundamentals-parallel-transport/ [www.entagma.com]
- Aizatulin
- 472 posts
