I had a sexy little dependency network in ROPs that would get run on our farm, (when JC isn't looking). However every time I ran the job I would get a different behavior from when I just hit the render button in locally in Houdini.
As it turns out when you hit the render button it renders the ROP and its dependencies frame by frame. But when you render a ROP via hscript using the render command it renders the dependency network node by node. To render frame by frame you need to start the render with render -I <rop_name>.
No big deal but it had me going “wtfbbq” for a couple of minutes. :wink:
