Trouble with Capture Geometry
2306 8 1- Danil Shaposhnikov
- 58 posts
- goldfarb
- 3455 posts
- 58 posts
- traileverse
- 355 posts
using the muscDH geometry, the problem with it I think is that the tetrahedralization is failing because the geometry is not suited to be tetrahedralized (It has holes and isn't conforming). One way I found to fix this is to use another piece of geometry to do the tetrahedralization (like a sphere, and shape it roughly to match the geo I want to skin) and that works or you could use a different capturing method. Check attached file.
Also if you're using the stash node, you should click the “stash input” button to re-cache the input geo or the deform SOP will still be reading the old geo.
Edited by traileverse - April 20, 2018 02:38:34
hou.f*ckatdskmaya().forever()
- 58 posts
miccetroThanks. Yes i know about “stash” and i was trying to close holes, remesh and it does not work.
I thought it was some hidden problem of the original fbx file, which contains many elements created in different programs. I still understand this little, this is the first rig on the Houdini. I may have to use your method, thank you.
UPD: i find another solution. It`s work with Enlarge Input Mesh offset! apparently the reason was too subtle details.
Edited by Danil Shaposhnikov - April 20, 2018 03:28:00
- traileverse
- 355 posts
Oh yeh true.
- goldfarb
- 3455 posts
Danil Shaposhnikov
yes - this is one of the issues with the biharmonic method - the output of the Bone Capture Lines SOP needs to be inside the tet mesh. You'll also have issues with those very thin sheets of muscle.
Edited by goldfarb - April 20, 2018 10:55:26
- goldfarb
- 3455 posts
- 58 posts
