Watermarking Wedge Sequence when rendered to MPlay (OpenGL)
1195
1
1
art3mis
April 21, 2018 4:06 p.m.
So I've read you can use the hwatermark program to watermark images when saved to disk, but what if you need to watermark images rendered to screen? More specifically, I need to be able to watermark changed parameters in a random wedge sequence, so I can identify which is which. Is there a way to accomplish this?
jsmack
April 21, 2018 10:59 p.m.
If you just need text, you can add the ‘viewport comment’ property to your camera. The text value of the parameter will be burned in to flipbook viewed through that camera.
