Hi there,
I've used the topo node before and it's super handy but now for some reason I cant seem to get it work
Can anyone see what I might be doing wrong here?
It keeps switching from add points to move.
Thanks,
Pete
Trouble with the Topo node
1119 1 1- peteski
- 517 posts
- derrick
- 327 posts
The parameters on the TopoBuild SOP are used to record what you did in the viewport. Since you moved a component in the viewport, the tool updated the TopoBuild SOP's parameters to describe this action.
Use the state's parameters (at the top of the viewport) to specify what kind of task you wish to perform, not the SOP's parameters.
