Hi!
Here you can se empty fbx files in Unity. Its supposed to be a complete square!
I have a big mesh I need to slice up and export multiple fbx files instead of one. I have a solution but it is not stable. Often fbx files are empty! This is my solution to export multiple fbx files. I press Animate frames same amount as I have fbx files to export. If you have som light to spread on this matter, then I am very grateful! Example scene is able for download. thanks!
Using Houdini 16.5.439
Export multiple fbx files unstable
2496 1 1- PeterHam
- 7 posts
- PeterHam
- 7 posts
So I solved it by make file->new asset and make it python type and write like
and then use boolean to export selection.
worked like a charm!
script like this
script like this
def onButtonPress(): node = hou.pwd() geo = node.geometry() #group Node Box = hou.node('/obj/Dressing/box1') BoxSize = 100 BoxX = -100 BoxZ = 350 #fbx node fbxNode = hou.node('/obj/Dressing/fbx_out2') exportPathBase = hou.parm('/obj/Dressing/exportLevel1/exportPath').eval() Index =1 Level = "Level2" exportButton = hou.parm('/obj/Dressing/fbx_out2/execute') #looping and exporting for x in range(0, 6): for z in range(0, 6): #update group selection Box.setParms({"tx":BoxX+x*BoxSize,"ty":0,"tz":BoxZ-z*BoxSize,}) #update fbx node and export newExportPath = exportPathBase+str(Index)+".fbx" fbxNode.setParms({"sopoutput": newExportPath}) exportButton.pressButton() print newExportPath Index +=1 hou.ui.displayMessage("------------------->Export Finished<-------------------")
Edited by PeterHam - May 30, 2018 06:41:21
