embed .ui file into HDA ?
3019
1
2
tas3d
June 4, 2018 5:33 p.m.
Im having trouble reading embeded widget ui file.
class MyWidget ( QtWidgets . QWidget ):
def __init__ ( self , * args , ** kwargs ):
super ( MyWidget , self ) . __init__ ( * args , ** kwargs )
ui_file = hou . readFile ( "opdef:.?widget.ui" )
tried also full path
ui_file = hou . readFile ( "opdef:/Sop/myHDA?widget.ui" )
or this
ui_file = "opdef:/Sop/myHDA?widget.ui"
Is it because readFile returns content of the file, rather then file itself ?
What it a proper way of reading embeded widget ui files from the same HDA ?
Edited by tas3d - June 5, 2018 06:39:53
Michal Tas Maciejewski @
www.vfxtricks.com
tas3d
June 6, 2018 6:38 a.m.
I got it working by saving extra files to temp file, then reading them in
type = hou . nodeType ( hou . sopNodeTypeCategory (), "xxx" )
definition = type . definition ()
sections = definition . sections ()
extraFiles = ( 'ui.png' , 'ui_mask.jpg' , 'widget.ui' , 'about.jpg' )
tempDir = tempfile . gettempdir ()
for f in extraFiles :
section = sections [ f ]
filepath = os . path . join ( tempDir , f )
file = open ( filepath , "wb" )
file . write ( section . contents ())
file . close ()
Edited by tas3d - June 6, 2018 06:38:44
www.vfxtricks.com
