I have exported the groups for objects with similar materials and i want to use the same group inside of houdini for calling them to material node.
I tried selecting the group and then using a delete node for isolating the specific group but that is really a long process.
So is there any easiest way of doing so?
Need to select Groups for applying materials
1103 1 0- Priyank Parekh2
- 7 posts
- Enivob
- 2536 posts
Drop down a Material node, connect it in and any groups that already exist on your geometry should be shown in the drop down list. Select a group from the list then choose the material for that group. You can add multiple materials on a single Material node so you only need one.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
