I just installed Linux Kubuntu 18.04 (Ubuntu Bionic Beaver) in my machine and i have been using Houdini with no problems in it, faster than in Win10, by the way. However, my second HD doesn't show in Houdini. I can see it in the Linux environment but not in Houdini.
In this case, how can i make it show up in Houdini? Mounting it to a different folder maybe?
Any help would be appreciated.
Thanks.
2nd HD not showing in Houdini installed in Linux
920 1 0- Marcolax
- 21 posts
- Enivob
- 2534 posts
Yeah, I run into the same problem with USB drives I plug in.
What you need to do is navigate to your root_drive/media/username and any mounted drives will be listed there.
Once you are there, you can select a folder and click the + button to add it to your sidebar.
Edited by Enivob - June 14, 2018 17:12:52
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
