Hi
I have a critical problem, and I need to figure it out ASAP.
I have a scene. The scene was about a city and some cars. When it was just a basic material it was fine (about 3 minutes to render in full HD), now I added more materials (5 to be specific) and drive the colors via per object overdrive the render of a single frame went up to an hour. I couldn't get it faster even if I turned off all reflectivity, limits, etc.
What I experienced so far, that over the day render speed gradually gets slower. For example after reboot, a simply torus renders within seconds. After a couple of hours, that torus won't render within 30 minutes. The first pass (or iteration) of the progressive render would take more than 2 minutes!
And this image was shot after the reboot render:
Guys, I'd appreciate any help.
Sudden speed dropdown over the day
1194 2 1- szmatefy
- 141 posts
- szmatefy
- 141 posts
This is the current situation. When I woke up I wanted to check if any frame was rendered from the scene I have to render, and although it was rendering over 8 hours, it didn't finish, and ETA was about 14 hours. So I restarted houdini and dropped the torus, and a Mantra PBR node and hit render. See the result and the elapsed time…5 minutes for this…
Originally my computer viewport performance dropped also, but I realized, that sleep mode killed it. When my PC entered sleep mode, after that opengl viewport became unusable. Now I disable sleep mode, and openGL is super, but render is still an issue.
Specs>
Houdini INdie 16.5.496
Intel i7-2700K (OK oldie, but it's fine with other apps)
16GB RAM
Geforce 1070Ti
Specs>
16GB RAM
Geforce 1070Ti
- szmatefy
- 141 posts
