I have a grid and two points (in this case), and when I use the For-Each Point to, for example, control de Y position of the points of the grid, the For-Each Point end creating one grid for every input point.
Is there a way to tell the For-Each to do the transformations in the same grid, instead of creating a new grid for every point?
If it is not possible, is there another to apply the transformation one by one?
In the screen you can see the result, a 10x10 grid (100 points), and the output gives me 200 points.
Thank you.
Regards.
For-Each Point Duplication
467 0 0- MartinGarciaFernandez
- 1 posts
