Hello, I'm trying to follow a Houdini tutorial and right now the goal is a waterfall, but the tutorial was made in Houdini 13, and I'm using Houdini 16.5. In the video the instructor makes a force node and makes adjustments in the noise tab, since there are now specific force nodes, I created a Noise Field force node to replicate it. In the video they adjusted roughness, frequency, amplitude, etc. in order to make the particles flow less consistently, but when I try to adjust the settings in the Noise Field node, nothing changes in the simulation.
I'm fairly new to Houdini and recently discovered VEX and used it a bit to help follow the tutorial, and I tried to find a way to solve my problem using VEX, but I'm just not well-versed with it enough yet.
I see the Noise Field force node has a green output, is there a special node I have to plug it into for it to apply, or am I doing something incorrectly?
Any help is appreciated
Noise Field Node Not Functioning?
571 0 0- CWan5
- 2 posts
