Hello world,
Trying to use hou.find() commands to separate out all the shaders in a hipnc/hdanc file. My goal is to create a list of all the image maps and their locations. So I may then create a convert tool that takes pngs and outputs .rat files to the appropriate locations so none of the paths in the shaders break.
How to remove all shaders & create a list of all the image maps used in them?
1541 2 0- Bub
- 2 posts
- malexander
- 5156 posts
- raschberg
- 20 posts
Hi, you could also use something like this in Python, try fo filter for certain extensions
def getFileRef(): import os.path import hou refs = hou.fileReferences() cleanedRefs = [] #check all filereferences amd return a list of attributes for ref in refs: refAsList = [] if ref[0] != None: parm = ref[0] fname = parm.eval() valid = os.path.isfile(fname) fileextension = os.path.splitext(fname)[1] refAsList.append(ref[1]) # file reference refAsList.append(fileextension) # file extension refAsList.append(valid) # file on disk? refAsList.append(fname) # resolved path refAsList.append(parm.node().name()) #owner refAsList.append(ref[0].path()) #parameter name cleanedRefs.append(refAsList) parm return cleanedRefs for item in getFileRef(): print item
