Hi there,
I am a total beginner of Houdini. I am currently following Jeff Wagner|Illume Webinar Tutorial Learning Houdini. The tutorial is fun and I followed step by step till around 45:00. After the rendering setting, my result looked totally strange. I thought it might be a normal reverse case, so I checked the normal and reversed it by using Reverse SOP but nothing changed. My rendering still look like a ball cluster. Please see the attached image. Did anybody experience the similar problem? Any help is highly appreciated. Thank you!
Ciao
Chao
Problem in following Jeff Wagner's Tutorial Learning Houdini
2031 3 1- ciaoZ
- 31 posts
- illusionistics
- 46 posts
- ciaoZ
- 31 posts
Hi illusionistics, thank you very very much. You are a saver! I went through my network graph and fund a purple tag on an inbetween node. I did not notice at all that I have ever turned it on. Once it was off, the rendering looked normal again. Such a small mistake yet I have no clue about it. There is a still long way to go. Thanks a lot!
- illusionistics
- 46 posts
