Hello, Im new to houdini.
I want to connect these points into lines.
When I use an add node to do this, it connects all the points in order, but does not have a point distance threshhold/control.
https://ibb.co/m5Azyo [ibb.co]
What is a good way to connect these points, based on their order, and distance to the next point in the sequence?
Thanks for reading.
How do I draw a line between points, based on distance and point order.
2184 1 1- soma wheels
- 27 posts
- Danil Shaposhnikov
- 58 posts
soma wheels
Thanks for reading.
i`m not shure, but you can try use Connect Adjacent Pieces, to connect all points, add attribute @cost to points and use Find Shortest Path node to connect on you order. This node search path from start point to end by lowest @cost
