Hi folks
Thank you in advance reading, and trying to help me.
I have a crowd (any crowd would do). The crowd is built using Mixamo and Adobe Fuse characters. I have to color each agent's top and bottom (jacket and pants) differently. To achieve this, I generate random colors, and store them in two attributes. The idea is to acces those attribute using stylesheet.
1. My problem is (and it's my fault) that I was testing the scene on one frame, and when I ran the animation, I realized that the random number generation happened every frame…How can I generate color randomly and store them in attribute without changing frame by frame?
2. I tried to use the Stylesheet, I understand now how it works, yet it seems it doesn't really do what I expect. Apparently the data read has nothing to do with the data on the given agent. If anyone could take a look, I'd appreciate it.
Lawyer.zip must be extracted to the agents folder of the project
Thanks girls and guys!
Help needed - crowd and storing agent specific data
1263 3 2- szmatefy
- 141 posts
- cwhite
- 727 posts
szmatefy
You should call random.seed() - otherwise you'll get different results whenever the SOP is recooked (which happens every frame because its input is time-dependent), or when you reload the file, etc.
The better approach, though, is to re-use some of the existing nodes that can do this for you - e.g. the Color SOP's Random option or the Attribute Randomize SOP.
The stylesheet renders fine for me, though
- szmatefy
- 141 posts
- szmatefy
- 141 posts
