Hello, I need some recommendations.
I would like to use the Creep node with the figure you can see on the picture.
As I can read in the help doc. I need the object to be a mesh or Nurbs surface, so I tryed to convert it with the convert node. In both cases I can only creep on a small polygon, but not all along up the figure.
I also tryed with the Ray node to proyect a tube all arround the figure, but the result is quite awkward.
Also took a look at the examples in the documentation but didnt help too much as the surfaces used to creep are very simple.
Can somebody give some ideas about what could be my mistakes or maybe recommend another way of doing it?
I include the file …attached file
Thanks in advance.
Using Creep Node with complex and irregular surfaces.
1088 0 1- Dav_Rod
- 40 posts
