Hello all,
Is there any way to constrain the rotation of a cloth object as well as its position?
I am attaching three cloth objects to a wire solver-the cloth objects are small and shaped like leaves- a bit rigid form wise. They are being attached to a branch coming off a stem(both simple wires). The wire and cloth objects are each being controlled by their respective solvers, and the relationship between the objects is set to constraint only (on the merge node). For the actual constraints, I am using the cloth stitch constraint (under the hood just a position constrain relationship– with the crucial SBD relationship as well). I am just using the pivot point of the leaf to constrain each leaf to the perspective point on the wire. The solve is actually stable, the clothstitch constraint works really well to constrain the cloth objects to the wire, however this is position only–in fact all the SBD constraint systems seem to be position based only. A traditional rotation anchor is not recognized by the two parties here. Is there a way around this?
Perhaps I could do something on a sop solver level if need be…..
Ive uploaded a file.
Thank you!
Rotational Constraints for Cloth
889 0 0- jtk700cln
- 45 posts
